Re: Zanussi WJD1457 Rinse fault
smartin wrote:clean the little holes directly above the softener compartment with a plastic bag tie or similar object.
Sorry for delay in replying.
Thanks to smartin, I cleaned the holes (with a pipe cleaner) and everything seems to be OK again. Thanks for the tip.
There is an “offline ” test where, by pressing various buttons in sequence, you can get the various functions to work. It’s a lot easier than, say, a full rinse cycle to get a particular sequence to run. I saw a repairman doing it when there was another fault but he wouldn’t tell me the method.
