When I set the machine to wash (any cycle), it fills with water, the water jet starts, then it immediately skips to the ‘drain’ setting and drains all the water out then stops.
If I persist it will usually complete the cycle after 6 or 7 tries.
The display does’t show any error messages, the time just skips from 2:01 to 0:03.
It would be best with that machine to go into diagnostics… it could, literally be anything, from worn brushes, to an overheating circulation pump, non-congruency between pressure switch and analogic switch, to a pcb fault itself.
Sorry to be so vague, but other than checking the pump filter and/or carbon brushes, it could literally, be any one of about 8 problems.
