I went to this machine because the indicator dial clicks around part way through a wash. I have tested everything including heater and brushes and changed the timer but still the same. When you put it on a wash it will take water in and start to wash but then after 10 minutes everything stops and the timer starts to click around . any help would be appreciated as i have already spent out on a new timer
Andy
Motor armature failure. This fault will cause the timer to ‘abort’ the cycle and click round to the stop position. The motor costs around £58 + VAT. (1249203009). Probably worth doing. 😉
