Hi Folks,
Looking to confirm the solenoid valve electrical plug & Pipe connections after changing the valve before I connect up water hose and switch machine on.
There are green black and white solenoids on the unit. At present I have the two separate single blade orange connectors on the black valve, the single blue wire connector on the green valve and the single orange connector on the white valve.
Then for pipes as you look a machine front I have the right hand water tray conenction going to the white valve, the middle water tray connector to the black valve and the left pipe to the green valve. Does this sound correct ?
