zanussi wjs1265 w washer dryer playing up
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi wjs1265 w washer dryer playing up
  • #13459
    surreyfrog
    Hi – wonder if you can help with this problem?
    The machine is around 3 years old and I’m getting a recuring problem, the front lights go out and the machine stops working.
    Following some advice I was given I took the top off and reseated a bundle of connectors that plug into a set of contacts behind the on off switch. THis cured the problem temporarily but it soon came back. I have had to repeat this many times over the past months and it’s becoming a right pain in the butt. Any thoughts how I can permanently cure the problem myself without calling out Zanussi?
    Many thanks.
    #155035
    Re: zanussi wjs1265 w washer dryer playing up
    surreyfrog wrote:Any thoughts how I can permanently cure the problem myself without calling out Zanussi?
    Sounds like the ribbon cable between the 2 control modules may need replacing? Best left to the experts in all honesty.
    You could try a local independent repairer here:-Repairs@
    #155036
    surreyfrog
    THanks for that Mike, unfortunately there are no repairers listed for my postcode.
    BY the way – are you a repairer? You don’t cover the SW corner of Surrey bordering onto Hants do you ??!
    #155037
    Dave_Conway
    surreyfrog wrote:THanks for that Mike, unfortunately there are no repairers listed for my postcode.
    If Martin can’t help, pop up your postcode and I’ll check a list I have here for you 🙂
    #155038
    No sorry I don’t go that far. There is a guy in Kingston that is registered on this site but again if he hasn’t registered on Repairs@ then you best call out these guys:-
    http://www.serviceforce.co.uk/
