Zanussi WJS1265W (914602005) Not drying
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi WJS1265W (914602005) Not drying
  • #53067
    Geoff1312
    Hi Guys,
    Went to above machine customer complained not drying well. Element ok, condenser clear, condenser valve ok.
    Ran machine with door open, plenty of air + heat to start with but after a time heat cuts out and doesn’t seem to come on again, but will if i start a new dry cycle.
    Any ideas please?
    Many thanks
    Geoff
    #314282
    lerch
    Re: Zanussi WJS1265W (914602005) Not drying
    Check the ntc in sump hose bottom right hand as you look at machine ??
    #314283
    lerch wrote:Check the ntc in sump hose bottom right hand as you look at machine ??
    Vent hose at bottom of condenser housing – broken wiring is an common problem.
    lerch
    Stand corrected 🙂 that is what I meant Vent hose. 😳
    #314285
    TheSpinDoctor
    Hi.
    Have you accesed the diagnostic to retrieve the last recorded error code & if so, what was it?
