Zanussi WJS1265W can’t set program. Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi WJS1265W can’t set program. This topic has 2 replies, 2 voices, and was last updated 18 years ago by Twoten. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts March 27, 2008 at 7:02 pm #35574 TwotenParticipant Called to the above machine, the display shows 3 horizontal bars and can not be set to wash. After cancelling, unplugging and fiddling about a bit I manged to set a program, pressed start and the 3 horizontal bars appeared again. Customer says this has been doing this intermittently for a while. I removed the PCB and tightened the contacts but this has not helped. Any ideas would be appreciated. March 27, 2008 at 7:04 pm #247168 WashmanParticipant Re: Zanussi WJS1265W can’t set program. Hi Check the door lock Mike March 27, 2008 at 7:58 pm #247169 TwotenParticipant Re: Zanussi WJS1265W can’t set program. Thanks Mike, I thought you could still program this even with the door open but not start it? I did link out the main contacts to see if it made any difference, all that happened was the door lock light came on! I have ordered an interlock for this as I normally carry one for van stock, when I have received it I will call back and give it a try. Thanks again, Keith. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
