Zanussi WJS1397W
  • #51074
    robbra
    Will fill and wash ok but no pump and when emptied by hand there is no motor on spin. I can’t get my TDS to load again. Does it sound like a pcb or a timer fault?
    Rob
    #306828
    Re: Zanussi WJS1397W
    Just pump probs or gunged air chamber I would imagine? PCB/timer last option TBH.
    #306829
    robbra
    Hi Martin,
    Pump is fine but no power to it and pressure pot is clear.
    Rob
    #306830
    aqualectric
    It is possible for a shorted pump to pop the timer on these; if you can trace continuity from the timer to the pump and the pump is OK; (I would plug on a new one with the machine leant back to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure) then it has to be timer.
    HTH,
    Steve.
    #306831
    robbra
    Steve,
    you were right again 😯
    Fixed that and then it pumped and filled at the same time when it should be spinning but no spin so she has a spare Bosch so keeping that.
    Thanks again and merry christmas.
    Rob
    8)
