Zanussi WJS1397W prod. 914639503/00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi WJS1397W prod. 914639503/00
  • #12969
    wishbone
    Hi all, have got this zanussi to look at on thursday,
    customer says whatever programme you put it on
    it fills then just clicks through the cycle quickly.
    dont remember having a zanussi doing this before.
    has anyone got any idea’s that might help?
    thanks in advance
    pete….
    #152402
    litlor
    Re: Zanussi WJS1397W prod. 914639503/00
    check that nothing is down to earth or the most common fault is not draining
    #152403
    Tony_EMW
    Most likely cause is the L shaped module Ako 546547. We keep them in stock if you want to try one. Tony EMW
    #152404
    Mark1
    This will be the timer. one of the internal cogs has jammed allowing the timer motor to engage the whole timer. Mark
    #152405
    wishbone
    Thanks for the replys.
    looked at it today and the fault was tacho coil
    hanging of the motor on its wires and magnet unscrewed.
    these refitted cured the problem.
    thanks again pete….
    #152406
    Simon46
    Those sole motors. What an earner. Great when you say to the customer the motor is faulty…… But it can be repaired for a small fee.
    S.
    #152407
    wishbone
    yes i was pleased, went expecting prog/module
    fault which usually results in customer buying
    a new machine…… 😀
