Hi, thought this was going to be a simple fault but scratching the head a little now.
This is an intermittent fault..when drying mode is selected the prog clicks round to stop..sometimes it`s ok and goes right through the cycle.
All the stats seem ok and the heater is fine….any ideas would be more than welcome.
Thanks in advance.
I`ll check when it next stops.
Is there anything else I could check as I can`t take it into the workshop as it`s in a nursing home and they use the washer some 3 times daily.
Thanks again Martin
It is usually an NTC fault that causes this, either the heater box NTC or the bottom hose one. Anything else would give out an error code like E10 or E20 (faulty valve and blocked condenser).
