My six year old machine (after heavy use) is now showing signs of bearing wear – loud whine when spinning. I’m trying to find the bearings and seals I need to fix this but the model is rarley listed on the usual parts web sites. Any help on part numbers / stockists would be appreciated. Also do I need a special tool to pull the bearings out?
I’m also intending to replace the drum seal at the same time, are there any other parts that would be sensible to change at the same time?
Many thanks for a great forum
Ian
