Zanussi WJS1665W error 10
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi WJS1665W error 10
  • #25675
    Cactusbob
    After searching here, I’m pretty sure that the error 10 that my machine is displaying when starting a dry cycle is down to a faulty 3 way valve.
    Just before I order one, can anyone confirm that this is likely to be the case and whether the valve is easily accessible? I seem to remember from my last venture into the machine (to replace the condenser fan) that the valve was at the top near the back, is this correct?
    Any help would be appreciated.
    Geraint
    #207017
    Re: Zanussi WJS1665W error 10
    Test meter across the solenoid coils is the only way to be sure.
    Valve is p/no 1249472-11/7 if required, spares@ukwhitegoods.co.uk will get one for you.
    Power off, of course.
    helo_75
    the green coil is the dryer valve….
    that what e10 is, that valve not working
    #207019
    Not entirely, Helo – 3 possible E10 faults, one of which is “problem with water during drying”. Hence, test meter to be sure.
    Cactusbob
    Thanks for the replies, I’ve got a valve so I’ll give it ago. Incidentally the condenser fan is making a right racket when it spins up and when it stops. I replaced it less than a year ago, any reason why it keeps failing?
    #207021
    Cactusbob
    Replaced the valve, nice and easy, all working again now. Thanks guys 😆
    #207022
    helo_75
    do you mean the condenser fan motor or the ventilator itself?
    #207023
    Cactusbob
    Not the motor, the belt driven fan bit
    #207024
    Dismantle the fan and lubricate the shaft with high speed grease. Reassemble and ensure no free play on the pulley. Spinning the pulley by hand ( with the belt attached) you should notice, as it stops, it should momentarily turn in the opposite direction (the spooky effect of a shaded pole motor 😉 )
    #207025
    Cactusbob
    Finally took it apart and slapped some car wheel bearing grease (lithium based stuff) on it. Re-assembled can hardly hear it spinning at all now, good tip, thanks a lot 😆
