Zanussi WJS166SW
  • #42728
    rocker
    There is no negitive feed to heater traced back to pressure s/w switching ok, sure this must orginate from pcb timer located at top r.h.s. tony at emw is unable to test or repair, would it be possible to repair (as in diswasher dry joint) or will it require new board. any advice would be welcome.
    John.
    #274695
    funkyboogy
    Re: Zanussi WJS166SW
    prob need new pcb , its one of those jobs that you need to fit part and see..
    ally
    #274696
    geoff1
    Neutral is via pcb and pressure switch. May be worth checking module for dry joint.
    Have sent a copy of manual via email
    Geoff
    #274697
    rocker
    Many thanks for your help gents, I will look for a dry joint Geoff.
    John.
    #274698
    The older Zanussi modules are very sensitive to relays with partially burnt switch contacts which check out fine on the test bench but don’t do the business in situ. (IME). Could be these new modules have similar sensitivity. Will be interested to know what you find. Wish the bl**dy things were easier to get out of that tight corner!
    Mike.
