zanussi z1 920/8 ff
  • #68366
    jim kelly
    my zaussi fridge/freezer is to cold even on the lowest setting,and ice builds up on the back wall at the top.it seems to be running a lot more than b4, even when not opened for a long time, help please
    #370768
    Dales-Electronic
    Re: zanussi z1 920/8 ff
    You need to find out what the actual temperature is in the fridge compartment. Once this is found you can diagnose if it is short of refrigerant or the thermostat/defrost system is defective
    #370769
    captaincaveman1
    If the ice build up is more in the top corner then the system has failed . Being built in they tend to work much harder and a lot of the time the installer doesent provide the correct ventilation on the wooden plinth at the bottom so that shortens the life even more.
