zanussi z1959t bearing kit.
  • #56268
    keithwilliams
    friend of mine has rung me to get him a bearing kit for this machine he says about 25years old. hes sure this is the correct number but i can’t find it on tds or on masterparts site.
    please can you tell me what the part number is for full kit or at least what size bearings and seal is in it. Its 250 miles from me so i can’t just pop around.
    thanks
    keith
    #326745
    Washman
    Re: zanussi z1959t bearing kit.
    Theres a Z959T listed on Connect
    Mike
    #326746
    pup
    thik bearing are same as hotpoint wm, could be wrong 😉
    #326747
    keithwilliams
    further info on this zanussi.
    he now tells me that spec plate says
    model code 80428x and
    f code 841000432 i’m guesing this means made in 1984
    #326748
    It’s probably a letter I not a number 1.The hotpoint kit would not include the seal between the bearing cross and the tub. It would be better to use part No. 344703012 or equivalent. ZI959T is listed in an old Homespares catalogue I have. Their part Number is 7646.
    #326749
    aqualectric
    It’ll be the large Zanussi bearing kit as used on the Z929T. Fitted in the 3 legged cast iron spider on the back of the metal enamelled tub. Easy job as long as the shaft is unmarked on the brass collar. Fantastic machine; part of the Washcraft series…. probably the best machines Zanussi ever made.
    Part number:- Genuine part:- DST344703012; Qualtex:- BKT27, Connect BRG942260.
    HTH,
    Steve.
