zanussi z816wt85bi washer dryer jumps to 11mins on dry cycle no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi z816wt85bi washer dryer jumps to 11mins on dry cycle no heat
  • #103037
    snig
    Machine jumps down to 11 minutes after a couple of mins on dry cycle. Seems to be just as the heater kicks in. Dryer element reading just 1Meg ohm so suspect that might be it. Anyone know how to access diagnostics on this model ?? Service number 914606603/03
    #491559
    normally its press start button and one of the buttons next to it and turn on
    have sent you some info
    snig
    Thanks for that. Seems very similar too older machine diagnostics. I’ll call back and check last fault codes
    #491561
    suedehead1
    I have the same machine doing the same fault, i replaced the cables running to the front NTC as one was broken but
    it still does the same.
    #491562
    have you put it into service mode and looked for fault codes
    snig
    i found a second ntc at the back of the tub below the pulley which was faulty. replaced and been ok since
    #491564
    suedehead1
    ok i will put it into service mode and check rear ntc thanks
