Zanussi ZBB7266
  • #75461
    robbra
    I have a faulty defrost heater.
    Looking on TDS I’m wondering how to extract the evaporator far enough to fit the new one without damaging the system. I got the housing out a bit but not too far. Is it a case of removing the plastic housing (how is this done? It was a solid block of ice holding everything together) and fitting it under the evaporator?
    Thanks for any advice.
    Rob
    #394995
    captaincaveman1
    Re: Zanussi ZBB7266
    The advice we were given by Electrolux was to some how raise the compressor up 😯 😕 but now we have been told that we have to replace the entire evaporator assy .I was called to one on Tuesday 3years old on a chargable basis and understandably the customer went mental so I just advised him to phone Electrolux and demand to know why it was designed with no view to be able to replace the element without incurring extra exspence 👿 . Even the tall built in freezer that you can pull the evaporator right out onto a table if need be weve been informed not to just replace the element so far I havn’t found out why and on that model the element has even been deleted from the parts list yet last week I went to an identical freezer badged as an De-Dietrich that the element had gone and they happily supplied the element .
    #394996
    robbra
    Re: Zanussi ZBB7266
    Thanks for the reply, don’t want to damage the system so will decline this one.
    Rob
    #394997
    Simon46
    Re: Zanussi ZBB7266
    Ive just declined one. Unworkable.
    S.
