Zanussi ZBF360 oven door handle
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZBF360 oven door handle
  • #71896
    I have received from Zanussi replacement door handle plus 2 fixing screws (plastic). The fixing holes at either end of the door handle do not appear to be threaded. It seems unlikely to me that the plastic screws would be able to cut a thread in the hard door handle(i.e. act as self-tapping screws)
    Am I missing something? Any information please
    PS I note that some earlier models are fitted with metal screws but in this case it would not be possible since the pastic screws have a larger unthreaded diameter, beneath the head, than the threaded section to act as a guide.
    #382731
    don
    Re: Zanussi ZBF360 oven door handle
    PNC number starting 949 needed to identify correct model please as there are 12 different versions.
    Don
    #382732
    PNC 949712290
    #382733
    don
    Door handle part number 3554052021 and the fixing screws 3543232015. Could be worth checking first of all your packaging to make sure you have the correct parts.
    Don
    #382734
    Hi Don
    door handle part number 3554052021 and fixing screws 3543232015 are correctly listed on the zanussi despatch note. The part number advised for the glass pannel is 3578469938. All part numbers correctly checked against received items.
    Arthur
    #382735
    don
    Well it appears you have all the right pieces for the job :tup: the screws must have been modified at some stage.
    Don
