Zanussi ZCE7700X fan oven cutting out.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZCE7700X fan oven cutting out.
  • #39216
    Fitted a new fan motor to this 3 months ago. Customer has rung up to say it’s now cutting out – sorry no more specific details available yet.
    This model seems to have a lot of cut out stats listed. Do they malfunction? Or is there some other cause?
    Mike.
    #261678
    wench
    Not entirely sure, but think there’s a main thermal cut out that looks like a tampon – (near top of machine) if it’s scorched, replace. Alternatively I’ve had the same fault with an intermittent power supply – loose connection on the cooker switch.
    #261679
    Re: Zanussi ZCE7700X fan oven cutting out.
    Thanks wench. Have booked it in for next Thursday. Now have the further info that cooking at 190 deg is OK, just takes a bit longer, but when temp. is set to 200 or more it cuts out and cuts back in after cooling.
    Mike.
    #261680
    bendaireboy
    nice tampon quote,definate fault its got 4 lead coming offof it and controls fan hence 200 degrees or more out it goes and restarts when cool,take it easy
    #261681
    Thanks bendy. Sounds like I’m on a winner here; though not quite sure why, when a toc cuts out, it’s the toc that’s at fault and not something overheating. 😕
    Looking for part on Conn and Mpt – can’t find anything fitting description will ring Zanussi agent Monday.
    Mike.
    #261682
    wench
    What can I say? When a machine has 2 or 3 stats and people ask which one you mean – if you say the one that looks like a tampon, they know what you’re on about. 😉
    #261683
    Micky 32
    I came across this fault last year on a machine exact same. In my case it was a cut out at that back of the oven on the left side looing at the front of the machine. It has a red spot on it.
    #261684
    Thanks Micky, looks like I better make it a two visit job.
    Mike.
    #261685
    Went to this one today. Put a thermocouple in oven and ran it up. Turned out stat is out of calibration by about 30 degrees, so when the dial is set to 240 it goes up to about 270 before the light goes out. The TOC (red spot, just where Micky said it was) didn’t cut out for me, though I had the back off and away from the wall. Am going to order new stat. Didn’t find the tampon so maybe not this model, unless it’s under the hob.
    Thanks again guys.
    Mike.
    #261686
    chippo
    The tampon is cable tied into the harness at the switch bank it is a cut in and a cut out fitted with 2 white wires and two blue.mostly fitted to aeg appliances.
    #261687
    Fitted the new stat and all is well now apparently, though she says the oven seems to run a bit cooler now so sounds like she’d got used to it being too hot.
    Mike.
