pnc 948905423-02.Had a look at this one today.Elderly couple bought this 18 months ago ex display and without packaging. The bottom oven trips power as soon as it is turned on.It has never worked.Oven cavity spotless.They didnt want to make a fuss :rolls: and they didnt bother returning it.Does anyone have any tech on this one. A wiring diagram would be great if poss.Suspect selector switch fault.Paul
Insulation test the appliance and then each component. Its likely that moisture ingression to one of the elements has taken place whilst in storage and is allowing a leakage to earth, dry out or replace once the component is identified ………. KenW …. I Rest My Case.
Thank you.Sorry I should have said that I have meggered the elements on this one. I would just like if poss to get a wiring diag to bring with me on next visit.Paul
one thing to add and that is on some occasions if the rear wall is touching or pushed in we have seen instances of the insulation short circuiting. What Insulation readings have you taken? also take an insulation reading of the convection motor as recently we have seen a spate of low insulation motors.
