Zanussi ZCV68300xa fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZCV68300xa fault
  • #96907
    GarethD
    Hello all….HELP!!!
    I have a Zanussi zcv68300xa free standing electric double oven and hob.
    Tonight whilst cooking the digital display turned off and both ovens stopped working. No lights, no fan, nothing. Strangely, the electric hobs still work fine. Any thoughts on how to remedy…was thinking thermostat, but that wouldn’t affect the display….I think? HELP….got 10 for Christmas this year!! Thanks in advance.
    #465311
    well first as always is to check electrical connection to the oven
    dave
    #465312
    GarethD
    All seems good, plus HOB works fine….
    #465313
    time to check the terminal block on the cooker. some blocks have brass links that if loose can burn out and stop pats of the cooker
    is the clock showing and setting ok ?
    GarethD
    Hi Dave,
    Clock/Digital Display went off the same time as both ovens (fan assisted and top element ovens). As said, all the electric hobs work fine!
    Got 12 for lunch next Tuesday……I feel a large pre christmas purchase coming up!
    #465315
    ok
    there are no thermal cutouts and if it was a clock problem the top oven would still function so I still think its a terminal block problem where all the wires come together
    remove oven and inspect block ( power off ) for signs of burning and loose terminals. there are a number of brass links that should be in place and the screws need to be tight. I think the fitter has not checked and one of them has burnt out
    there are a number of units with the same model number but your term block should look like below
    GarethD
    OK thanks. Will take a look tonight. Hopefully easy fix if thats the case. Thanks for the advice. G
