Zanussi ZDC 37200W condenser completely dead
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi ZDC 37200W condenser completely dead
  • #82668
    foxfan
    Hi all,
    First post….
    We have a zanussi tumble dryer, model details above, and it has just completely died. It won’t turn on at all, no lights or anything.
    It is only just over a year old. I have checked the fuse in the plug and that is fine. There haven’t been any odd noises or problems prior to it dying and it is in a well ventilated position,reservoir emptied each cycle, filters cleaned each cycle, condenser cleaned regularly etc.
    Any ideas, hints or tips much appreciated!
    #420542
    Re: Zanussi ZDC 37200W condenser completely dead
    But have you tried the wall socket or plugged it in elsewhere?
    #420543
    Seamy
    P.C.B required
    #420544
    foxfan
    Thanks for the info, yep I’ve tried a different socket and checked the original socket too.
    PCB…. Is that easy to do, costly etc?
    Cheers
    Seamy
    Costing from £100 to £140 for part depending on which product you have, fitting it depends on how competant you are. Its a straight swap over.
    You need to have PNC off your own appliance to determine which P.C.B is required for your product..
    http://shop.electrolux.co.uk/search?ssv … c=7&pffv=0
    #420546
    foxfan
    Thanks Seamy, from memory it only cost about £200 new so might be better off just getting a new one and having a refreshed warranty?
    #420547
    Seamy
    Contact the manufacturers first, explain the product is just over a year old, ask if they will repair it under warranty as its failed completely just out of guarantee. Don’t tell them you’ve opened it or checked anything as warranty will be voided.
