Zanussi zdc37200 dies after 4 min
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi zdc37200 dies after 4 min
  • #78680
    deltra
    Hi, dryer runs clockwise ok for about4 mins. ( does heat up) stops,goes anti clock for a few turns stops,then won’t go clockwise again 😯 just sits there ❗ leave it like that and the tank light comes on…if I knock it off and start again it does the same!, any ideas ❓ Thanks
    #406525
    Re: Zanussi zdc37200 dies after 4 min
    NTC at the front would be the first thing to check. Have you tried diagnostics to find out last error code recorded?
    #406526
    deltra
    Hi martin, don’t know how to enter diagnostics!! Got no info on these at all. My thought was maybe reversing timer? Don’t even know if it’s got one,or is it all controlled by pcb?
    #406527
    Perhaps it’s best you email me and I can send you the service manual then. Be sure to remind me in the email what you’re after. 😉
    #406528
    Seamy
    Don’t think theres a reversing timer in this one, its a board controlled jobby.
    They will normally run, heating for a few minutes then if the float switch is made they will knock off.
    Check the float switch contacts as theres been an issue with them being problematic, also the NTC as mentioned before.
    #406529
    deltra
    Thanks for that
