Zanussi zdc37200w not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi zdc37200w not heating
  • #100732
    Unnameable
    Hi all,
    I have a Zanussi zdc37200w that has suddenly decided not to heat at all all.
    I’ve checked continuity across the heating elements and both thermostats attached to the heater, and all ok. I’ve also pulled the temperature probe and checked resistance, 4k ohms at room temperature.
    Anything else I should be checking?
    Cheers
    #481931
    probe listed as 6K at v20 degrees and 1250 at 60 degrees
    Unnameable
    Thanks, I’m guessing it’ll be reporting up to temperate already? I’ve ordered a replacement, so fingers crossed it sorts
    #481933
    Unnameable
    No luck sadly, still cold. Guessing it could be control panel?
    #481934
    have you tried a timed programme
    also did you have wet clothes in as a lot of units sense wet before they will heat for energy saving
