Hi. I’ve a Zanussi ZDC47100 condenser dryer then has just stopped working.
No LEDs are lighting on the front panel and nothing happening when turned on.
Ive checked the power to the machine and all is well. Ive stripped the machine panels and tested current on the internal cables with a volt stick. When set to a program Im getting current to the control panel, to the door switch and around the machine on the smaller, thinner set of wires. When i open the door the thicker wires then have current to the heater and the motor. The panel lights are still dead and no response from the machine. The door switch still catches and makes a click.
PCB control panel fault or something simpler?
Any ideas?
