zanussi ZDC47100W condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi ZDC47100W condenser dryer
  • #96821
    darren14770
    Hi this zanussi dryer is dead
    ​​its a PCB fault .Think link switch LNK304GN is faulty have ordered new one , but it has also blew resistor at R53 on the board trying to find the value think its 47R 5{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} 3w . Would anyone be able to confirm this for me . Thanks in advance. Tried to upload photo but no joy said was to large
    #464926
    value sounds about right but make sure its a fusible resistor you replace it with
    darren14770
    Thanks for that took old resistor out the value is 47R 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but does not say what watt it is , bit of it blew of may have been printed there .
    #464928
    Specialist01269
    Normally around 3 watt, somewhere like CPC or RS should stock suitable replacements.
    #464929
    Specialist01269 wrote:Normally around 3 watt, somewhere like CPC or RS should stock suitable replacements.
    BUT it must be fusible !!
    they are hard to find on RS so I looked it up for you
    https://uk.rs-online.com/web/p/through-hole-fixed-resistors/8558734/
    Specialist01269
    Yes Dave, but you’d already made that point. So as far as I’m concerned, my Reiterating it would have served no Useful purpose.
    #464931
    darren14770
    Yes I know it has to be fusible as it is doing 2 jobs . But thanks for the warning
    #464932
    trying not to nag, just making sure. Its one of those things that if you get it wrong you may be on the wrong side of a law suit and none of us want that
    hope you get it sorted as it makes a cheap repair for the client. changed lots of these chips and 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it works
    Specialist01269
    electrofix wrote: Its one of those things that if you get it wrong you may be on the wrong side of a law suit and none of us wants that
    Not disagreeing with you Dave, But surely that applies to virtually any repair you carry out on an appliance. Should your repair cause damage or injury then your liable to feel the weight of the Law.
    #464934
    agree which is why any components we install should be fit for purpose especially any safety components that prevent shocks or fire
    Specialist01269
    Dave: Believe me, when it comes to safety then we’re both way up at the top of the same page. But these are the trade forums, when one of us tells someone that something is a Safety item then they should take that on board with the first telling. It shouldn’t be necessary to repeat the same advice again, the public side is a different matter.
