Zanussi ZDC67550W (916096169 01)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDC67550W (916096169 01)
  • #96255
    Toni
    HI,,
    After going into diagnostics it comes up with E54 (5 X Red + 4 X green)
    I have fitted both capacitors to this both genuine as before it was just humming.
    Could it be the motor or module ?
    Any help much apprciated
    #462804
    Hollytree_Technical
    If the motor is humming then the module is trying to power it and unless it is low voltage to the motor (unusual and unlikely fault) then I would be looking at the motor and/or capacitor.
    Try flicking the drum round when the motor is humming and it should run – if not it may not be getting power.
    Check the windings on the motor – there should be 4 connections, (disconnect capacitors for testing) between pins 1 and 2 should be around 58 Ohm and between pins 1 and 3 should be 29 ohms (also between 2 and 3).
    Double check the capacitor – according to the service manual it should be 9uF rather than the usual 8uF.
    Jem
    #462805
    Hollytree_Technical
    Actually you may need to double check the capacitor values even more as there is a technical bulletin which list multiple other possibilities.
    Jem
    #462806
    Toni
    Thanks Jem
    I fitted both genuine capacitors for this model a few weeks ago
    There is no humming from the motor, but you can hear a slight click coming from the module when its trying to switch the motor on I assume
