Zanussi zdc8202p
  • #92117
    lardman
    Morning all.
    I have a zdc8202p bought 18 months ago from a well known online retailer, no extended warranty and it only has a 12 month manufactures one. For the past 2 days I’ve been getting a red led on the start/pause button and 3 beeps about 15 minutes into any of the programmes, this continues until the end but it does look like the programme finishes.
    I can’t find any info online or even what the error is. Any help, is it safe to still use? I’ve cleaned the filter, the condenser and the water tank is empty. Obviously I’m less than impressed at the early failure just beyond the warranty period.
    #450321
    Re: Zanussi zdc8202p
    I think its a conductimetric sensor problem ie moisture detection
    cant think of an easy fix unless you use tumble dryer sheets that tend to coat sensors and cause problems
    lardman
    Nope – nothing’s been in there but clothes. This afternoon it doesn’t appear to be drying at all, the clothes are wet, it doesn’t feel like there’s been any heat at all and the water tank is completely empty after a cycle.
    #450323
    unless there is heat there will be no water
    try a timed dry cycle
    lardman
    I don’t think there’s a timed cycle is there ? All I have are pre-programmed options, cotton, synthetic, mixed, wool etc. I’ve tried the “refresh”, “cotton” and synthetic options so far all appear to do the same. 15(ish) Mins in flashing red LED, 3 beeps. The drum turns freely, there are no funny smells and I’ve tried it on a different ring main.
    #450325
    lardman
    Just spoken with Zanussi – no help on the warranty, 12 months only. They want £130 for a callout but parts MAY be extra, the fixed fee isn’t fixed. :rolls: She did imply the fault was probably the controller. ❓
    Can anyone tell me how to put it in diagnostic mode so I can find out just exactly what’s going on ? There’s no LED display or selection wheel on this model and I can’t find any info online.
    I’m beginning to think I should have just bought cheaper and binned it when it went faulty.
    #450326
    lardman
    Feel bad replying to myself but … 😉
    I think I found diagnostics mode, whilst there I get 6 red flashes and then 3 orange flashes on the pause/start button, I don’t appear to be able to do anything else in there though?
    I’ m guessing this is error 63 thermostat fault which is a new heater unit. Im happy enough to drop the back off and disconnect to test and get part numbers.
    Does it sound like Im on the right track?
    #450327
    lardman wrote:Does it sound like Im on the right track?
    Yes indeed. Not heating then first thing to establish and check is the heater unit. :tup:
    #450328
    lardman
    Had to put this on the back burner but Im back at it now.
    I’ve dropped out the heating unit and put the meter across it. I’ve got continuity between red and black but 100ohm resistance. Am I right in thinking this should be 50ish and it is faulty?
    I can’t find the part on here but it’s listed elsewhere around £120 so Im keen on a second opinion.
    #450329
    https://shop.ukwhitegoods.co.uk/1366110 … ng-element
    this should be the element but to be certain you need your pnc number
    from the model I looked up there are 2 elements 1900 and 700w so will get 2 readings one about twice the other. check the stat on the element for continuity
    if you get any low ohm reading the element is probably ok
    lardman
    I’ve replaced the element and the problem is still there. 3 beeps and red led about 15 minutes in. Things are getting hot (perhaps too hot for the cycle?) and water is in the drawer. I suspect the problems is after the element and I burnt the last one out.
    Any other idea’s or it’s heading off to the tip.
    #450331
    bixbarton
    I’ve got the same issue.
    Replaced the element, things were then okay for a few hours, dried some clothes as usual.
    Then it went wrong again. Only cold air, and the red flashing light. Ran diagnostic, code 63.
    So must be a problem with a sensor somewhere or the mainboard? Also worries me that it has burnt out the new heating element in the process.
    Does anyone know where the sensor would be? I can find where to order them from, but no diagrams of where to find it on the drier.
