Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Zanussi ZDC8202P Lindo 300 Condenser Dryer Error Code Help (no LCD model)
- This topic has 12 replies, 2 voices, and was last updated 4 years, 12 months ago by
PitRejection2359.
April 11, 2021 at 12:31 pm #99402
PitRejection2359
ParticipantHi All,
I have a Zanussi ZDC8202P (NOTE: wrong number in post title!) Lindo 300 Condenser Dryer (model without an LCD) that is having a frequent issue. It will often start fine, but at some point in the cycle (any cycle) it stops and the start button flashes red and the unit beeps. It flashes about once a second and the beeps are 3 very quick beeps in about 0.5 seconds, 3 times about a second apart. Then there is a gap in the beeps for about 10 second while the red flashing continues, then it cycles through again. I’ve taken a video of it – hopefully I can link / attach it somehow!
The error normally occurs mid or most of the way through any cycle, and no matter what I do I can’t clear it unless I turn it off at the wall and leave it for a few hours. Its been getting gradually worse, and happening more often. I’ve taken the back off and cleaned all round the heater element (which wasn’t that dirty / dusty / fluffy) as well as all round the condenser and filter, but that hasn’t improved it at all.
Can anyone help identify what the issue is before I start taking it all apart in the vague hope that I can seen something clearly wrong with it? Many thanks in advance!
April 11, 2021 at 12:36 pm #476222PitRejection2359
Participantlink to video: https://imgur.com/a/XFtkpyR
April 11, 2021 at 1:50 pm #476223electrofix
Moderatorare you sure of the model as i cant find it
can you post the pnc number from the model label
April 11, 2021 at 2:36 pm #476224PitRejection2359
Participantelectrofix wrote:are you sure of the model as i cant find it
You’re right – I missed out a C; its ZDC8202P – I’ll update the title!
EDIT: I can’t update the title, or the first post – maybe a mod can do it for me?
EDIT 2: link to image of product No sticker: https://imgur.com/a/WDdxQUfApril 11, 2021 at 3:26 pm #476225electrofix
Moderatordoes the red start led flash just red or are there yellow flashes as well
count the red flashes and see if there is a pattern to it.. if you get past 20 there is not
April 11, 2021 at 7:23 pm #476226PitRejection2359
ParticipantHi Dave,
electrofix wrote:does the red start led flash just red or are there yellow flashes as well
count the red flashes and see if there is a pattern to it.. if you get past 20 there is notAs can be seen in the video, the start button just flashes red (no yellow) every half second or so continuously, so no pattern at all. The only pattern is in the beeping!
April 11, 2021 at 8:55 pm #476227electrofix
Moderatorhave you tried opening and closing the door a few times to see if it will start then after it fails ?
April 11, 2021 at 10:04 pm #476228PitRejection2359
ParticipantNot tried that, but leaving it for a few hors turned off without repeatedly opening the door does allow it to start again. Are you thinking its a door catch / sensor issue?
April 12, 2021 at 8:00 am #476229electrofix
Moderatoryes was wondering if the door sensor reacted to heat
April 12, 2021 at 11:52 am #476230PitRejection2359
ParticipantOk, I’ll try that next time. Is there any way to get a decode of the fault code?
April 14, 2021 at 10:20 pm #476231PitRejection2359
ParticipantHi Dave – we’ve tried opening and closing the door a lot when the red error lights and beeping start, but it doesn’t help – the only way to clear the issue temporarily is to leave it for 30+ minutes and then start it again.
Any more ideas of areas I can easily check before I have to call someone in?!
April 14, 2021 at 10:58 pm #476232electrofix
Moderatorit gets more complex now
you would need to know how to put the machine in diagnostic mode and then be able to find and interpret the fault codes
since this info is not available to the public you may need professional help to do this
April 15, 2021 at 9:14 pm #476233PitRejection2359
Participantah gutted…..
