if you switch off at the socket then on again does it come back to life ?
does sound like a board problem. Assume you have looked for earth faults ( not sure if heater earth faults can affect a dryer )
as far as I can see there are no cut outs in line with board power in so looks like a board power failure. maybe just power chip failing and needs to be replaced
