Zanussi zdf 501s
Viewing 15 posts - 1 through 15 (of 15 total)
  • #51518
    toddjohn
    I have a problem with my just out of warranty dishwasher it as worked fine until about a month ago when the wife said she came home and dishwasher had stopped mid cycle flashing .20 on display .She reset by pressing 2 buttons together and it restarted and finished ok .But it as got progressably worse and now stops 2 or 3 times each cycle always displaying .20.I have rung local shop and guy said this is definatly the control board and quoted me £155.00 to repair i just thought i would sound out problem on here to see what you guys think .
    Thanks in advance Todd
    #308360
    Re: Zanussi zdf 501s
    Drainage not detected in the time allowed. Partial blockage also check sink spigot if appropriate.
    toddjohn
    Thanks for reply i have opened machine up and then poured water into mid cycle restarted and it pumps water away straight away i pulled out pipe from waste and when machine is started it pumps out strongly into sink all filters are clean is there anything else i can do ?
    Thanks Todd
    #308362
    There is a matrix on the r/h side of the machine, with the water level switches attached to it. The hoses connecting the matrix to the sump bowl of the machine can (and do) clog up, causing the pcb to receive false readings. The matrix itself can get gunged up as well.
    Power off if you’re going to have a look at this yourself.
    toddjohn
    thanks will try that
    Todd
    #308364
    toddjohn
    Thanks for all help so far i found matrix removed and flushed through and replaced restarted but same symptoms so iturned machine on its back and removeved pipework off all easily accessable parts and flushed through restarted and machine worked fine for a couple of runs thought brilliant sorted .But went back into fault on third run tipped over again ans where you fill salt into machine through cap inside emptied water out of there cos it looked pinkish back upright worked fine for a couple of runs again but again faulted so again tipped over removed pipe of salt container removed water again worked ok, Now to make a fool of myself could salt container have any effect or do you think when it goes onto its back something else clears else where to make it run ok for a while.Please dont laugh at me do i need humouring lol
    Regards Todd
    #308365
    toddjohn
    Zanussi
    The error i recieve is .20 pump is working fine matrix iss are clean could this still be a pcb problem .Could i send it somewhere to check out and repair if needed or do i need to buy new one.
    regards Todd
    #308366
    .20 is time out on drain – it still thinks it’s full of water. You either definitely do have a blockage somewhere, or the level switch is malfunctioning (unusual).
    toddjohn
    Thanks for your input Penquin if i remove the right hand panel and remove bracket holding what i think you said was level switches and remove pipes blow down them sorry not very professional then replace the machine starts straight away and goes through programme but i cant find any blockage . When another cycle is started it may go halfway through and then stop again with .20 fault again if i remove and do as above again restarts and completes no problem do you think it is pointing at level switch problem or is there somewhere else i may find blockage .But iuf i tip water in it and switch on it pumps out really well in seconds
    Thanks for your help so far
    #308368
    When the machine refuses to fill, (With the power off) remove the air hose to each pressure switch in turn. If you hear a click, that switch was holding in the full position, despite the machine being empty. Follow the hose…..
    toddjohn
    Thanks Penquin
    Sorry nt got back sooner but working away Did what advised when machine showed display .20 and would not fill turned off and disconnected hoses neither made a click which i could hear so i blew down through tubes and made sure electrical connections were ok on switches no resistance at all when blowing through re assembled and switched on machine started ok immediately do you think this just be a faulty switch ?
    #308370
    toddjohn
    Thanks for all input so far do you think even though when i disconnect water switches no click is heard but as soon as the tubes are removed then replaced again the machine works fine for a cycle would it be a simple4 fix to replace water switches or switch and if so can i get them easily get them or can i test the switches that are on there anyway to determine if they are faulty
    thanks Todd
    #308371
    Test meter. Each switch is normally closed across contacts 1-2. When pressurised contacts 1-3 are closed. When depressurised, back to contacts 1-2.
    toddjohn
    Thanks Penquin i will test as soon as i get chance really appreciate all of your help and advice
    Todd
    #308373
    toddjohn
    Penquin45 just a update you are top bloke did as advised tested level switches and one was faulty picked up one on ebay for £6.00 refitted all working fine.Big thank you for your help and patience and if i had listened to local repair firm and not had your advice would probably taken dishwasher to the skip and bought another.
    Regards Todd
