Zanussi ZDF290X not warming up – replacement part
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi ZDF290X not warming up – replacement part
  • #83481
    FloydianSticks
    I have a built in Zanussi ZDF290X double oven where the main overn isn’t warming up. The internal light comes on and the fan starts. However, the light on the outside to indicate the oven is warming up does not come on at all.
    We have to cook Christmas dinner in a couple of days time, so hoping I can just replace the heating element. I found this one here:
    http://shop.ukwhitegoods.co.uk/31102310 … ment-11391
    However, my question is, is this going to resolve the problem? I appreciate its hard to say without seeing the oven 🙂 but I’m not sure if the warming up indicator not coming on indicates another issue? Maybe with the thermostat – I assume there is one 🙂 If the heating element was broken I’d expect the warming up indicator would be on constantly. But I don’t know anything about ovens.
    Does anyone have any comment/expert advice?
    Many thanks in advance for your help.
    Andy
    #422858
    SAMURI
    Re: Zanussi ZDF290X not warming up – replacement part
    If the fan is working then the thermostat should be ok.
    The most common fault would be the element.
    It may be just a neon fault if the the light is not working but it is hard to know what the fault is without testing it.
    Bob
    #422859
    FloydianSticks
    Thanks Bob. The quick response is much appreciated.
    There is a label on the oven that says it is 5-5.5Kw, the element that I found on eSpares says it is 2.5Kw. I cannot find a 5Kw version. Does the oven only say 5Kw because there are two parts to it?
    Andy
    #422860
    Andy jones
    The element won’t be 5kw.
    #422861
    SAMURI
    The link you have to E spares is correct it is a round 2.5kw element.
    Also try the WTA shop it might be cheaper.
    Bob
    #422862
    FloydianSticks
    Thanks everyone. The part is on order. Arrives Tuesday. Fingers crossed for Christmas dinner!!
