Zanussi ZDH8333P (916097690 00) Dryer not Heating Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZDH8333P (916097690 00) Dryer not Heating This topic has 5 replies, 3 voices, and was last updated 6 years, 6 months ago by jontymox. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts September 17, 2019 at 3:43 pm #96414 jontymoxParticipant Good afternoon, Wondering if anyone can assist with the above problem on this heat pump type dryer? Essentially, it isn’t heating and there are no fault codes displayed. I haven’t had much experience with heat pump dryers, and having had a good look inside there is nothing obviously amiss. Perhaps there is a diagnostic sequence that can be performed? Kind regards, jonty September 17, 2019 at 7:03 pm #463260 electrofixModerator they don’t heat well they do but its hard to tell sometimes the only heat in the system is waste heat from the compressor so its not a lot consider this more like a de humidifier and not a tumble dryer because that’s how it works use it and see if it dries Dave September 17, 2019 at 8:56 pm #463261 electrofixModerator should be able to get tech if you need it Dave September 18, 2019 at 8:57 am #463262 iadomModerator I did send the tech info to Jonty late last night, hopefully now received. September 23, 2019 at 6:23 pm #463263 jontymoxParticipant Good evening Dave & Jim, Update on dryer: carried out diagnostic test procedure, and the only error code present was E32 which is incurred during such procedure. The customer has agreed to monitor the dryer, and to allow more time for drying as she expected much faster drying results. Thanks again for your assistance, jonty September 23, 2019 at 6:47 pm #463264 iadomModerator If your customer has internet access you could send them a link to this article. 😉 https://www.ukwhitegoods.co.uk/help/buying-advice/tumble-dryers/3845-are-heat-pump-dryers-worth-it Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
