Re: ZANUSSI ZDI6053X 911929218/02 DISHWASHER
Just found this, don’t know if it helps
If the electronic board detects a fault value from a sensor of the dishwasher at the start of the cycle, after 10 seconds of draining, it performs a check of all sensors for a period between 3 and 5 minutes, and no single component is activated.
leave switched on for 5 minutes, after which the program should return to normal as this may well be the only issue Reseting the program during the diagnostic test will only postpones the start of the cycle
Colin
