Ok, I have a zanussi ZDQ895X double oven which has an odd problem.
Basically I switched on the main oven (fan oven mode) and and within 5 mins the electrics tripped. I switched the sparks back on and found that the oven would not come up to temp in Fan Oven mode when I switched it back on.
Ive checked the conventional oven and grill mode and they work fine but think that the heat is generated by the element at the top of the main oven..!!!
The fan in the main oven operates ok so Im wondering is this purely the main oven element that is at the back of the oven that has given up or is it something more sinister..
Any help/advice would be much appreciated
thanks
steve
