Re: Zanussi ZDQ995X heating fault
with the conventional oven ok that would lead me to say the temp sensor is ok ( unless there are 2 sensors )
so it sound like your pcb
but
i would check the voltage on the element while it is running with a veiw to the following
1 element fails as it get hot long shot but you cant dismiss it till you have tried
2 relay that controls the element is faulty
am not in work at mo so i cant check if i have tech info on this. if its built before pm me will see what i have
