Zanussi ZDT 6894 no fill
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Zanussi ZDT 6894 no fill
  • #10096
    Simon46
    Have cust with above integrated dishwasher product number 911896058 serial number 20710046 and have seen it four times for AL5 no fill fault. have cleaned IWMS/ hoses repeatedly but now require the conversion kit and IWMS. interestingly closing the inlet tap to impede flow has made my last cleanout/repair last over a year. what is the part number for the kit and does it come with instructions as it will be the first kit i have fitted.
    Many thanks
    S.
    #138286
    Re: Zanussi ZDT 6894 no fill
    1524624-20/0 – about £47 list. Last one I did didn’t have instructions, but it was pretty obvious once you started offering things up.
    Cheers,
    litlor
    hi simon
    taken this off TDS cd
    a) Tap closed
    b) Fill tube bended / intervention of Aqua stop device
    c) Mains water pressure < 0,3 bar
    d) Intervention of anti-overflow device
    e) Water fill solenoid/ wiring interrupted
    f) Pressure switch faulty / Wiring disconnected
    g) IWMS- pressure switch tube obstructed
    h) Central filter clogged
    i) Excessive foam
    l) Dishes upside down
    m) Siphon created in drain
    check above before changing IWMS i used to work for Zanussi and changed loads of them theres no instuctions and its a messy job, water everywhere
    John
    #138288
    Simon46
    Cheers Chris.
    #138289
    Simon46
    John
    Have “trained” customer in dishwasher care but notice a box of finish 3 in 1 tablets in cupboard. Could this be causing problem? job to be done in garage anyway.
    Thanks for list
    Regards
    Simon
    #138290
    Always…….. Excess froth and foam, poor heating as a consequence, salt in the wash – it just goes on and on.
    litlor
    Simon
    Justed looked at my service bulletins 3 in 1 tabs ok and if working in garage no prob with the water
    regards
    John
    #138292
    Simon46
    Just for interest put my fairy liquid sink washed plates to test dishwasher hotpoint BFI62 (indesit). listen to that wash pump churn that foam and watch the undertray fill with water.
    S.
    #138293
    litlor
    that will do it every time
    #138294
    Simon46
    Does it come complete with new IWMS?
    S.
    #138295
    Simon46
    Received IWMS kit.. Is there any modifications from the original to this one? I was expecting to see a double solenoid valve to be fitted in kit. This has single solenoid with diaphraghm.
    Regards
    Simon
