Zanussi ZDT12011FA fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDT12011FA fault code
  • #93022
    boselecta
    Fault code comes up at end of the cycle and it beeps and stops
    The third LED flashes, this says its a NTC sensor fault.
    Has anyone else solved this one by replacing the NTC or could it be the dreaded PCB making the machine beyond repair!.
    #452922
    Re: Zanussi ZDT12011FA fault code
    cant confirm your fault codes as code is dependant on the number of flashes the light makes not its position as far as I can see
    also tech shows this one needs the pressure switch mod if not already fitted
    boselecta
    I didnt see the pressure switch that gets blocked on the sump it has the old type pressure switches.
    There are two audible beeps and the end light is flashing twice.
    Thank you
    #452924
    well all the tech from lux says otherwise on the model and pnc number
    looked up pressure sw part number and its 14000 05 54-01 / 8 which is the later type
    take it you are certain of the numbers if yes cant answer. could send you all the tech on these numbers but it looks like it will be useless
    have pm’ed you the parts info so you will see what I mean
    boselecta
    Do ypu have the fault codes for this machine you can send me as I can’t find them anywhere?
    #452926
    sorted
    have sent you a lot of reading
    have done a screen dump of all files listed for this pnc
    have sent you the 3 service mans listed at the bottom. if you want any of the others let me know
