I have a ZDT12011FA (PNC 911 539 107 01) that the other day had a flood alarm activate. Didn’t realise until the next morning and the pump ran over night emptying the inside of the dishwasher of water. I took the lower front panel off and found water had activated the anti flood switch in the base.
After clearing the water out I cleaned the filter and checked the waste hose was not kinked and set the dishwasher off again. After a couple of minutes the dishwasher stopped and beeped then continued to beep every 20-30 seconds. On opening the door water was pooling inside the dishwasher. Couldn’t reset so had switch off at the wall and restart which meant it overflowed and emptied into the base and activated the anti flood switch that set the pump off and drained the water.
Not sure why water in not being drained/pumped out during the normal dish wash cycle? Does anyone have any idea what the problem is and how I can fix as the dishwasher is out of warranty?
Thanks, Olly
