Zanussi ZDT21001FA – 91153913502 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDT21001FA – 91153913502 dishwasher
  • #98095
    WhiteVanMan1
    Dishwasher drain pump runs constantly. No water in the base and the float switch is ok. Any ideas please? I’m thinking PCB? Any help greatly appreciated. Cheers. Steve.
    #470870
    as long as house has RCD trips then yes sounds like a shorted triac on the board. if no trip check for earth fault as pump is fed live and switches neutral. have you tried disconnecting float switch ? in case its short inside although i assume you have checked for this
    WhiteVanMan1
    Hi Dave. Yes I checked the float switch. All ok. Cheers Dave , thank you for your help. Steve.
