Re: Zanussi ZDT21001FA HEATER ASSEMBLY
from what I can see it would mean removing the main motor as the heater is mounted on the front of it
after removal there seems to be 3 possible types so the correct one would have to be ordered
it is possible that the heater is not faulty and your fault is somewhere else. you would need to check the heater and this can usually be done before removal to save time using a multimeter to check the resistance of the element
