Zanussi ZDT21001FA running forever.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi ZDT21001FA running forever.
  • #99479
    JamButty
    Hi all. Hoping someone might be able to help me please.
    Our integrated Zanussi ZDT21001FA dishwasher seems to get stuck on the rinse cycle and run forever, endlessly rinsing the dishes.
    It’s 5 years old.
    It heats water perfectly during wash stage.
    Doesn’t seem to heat anything during rinse stage (no idea if it should).
    I’ve replaced the turbidity/temp sensor.
    I haven’t noticed any error codes before. Any idea how to do a diagnostic cycle on these? All/any help appreciated!
    Many thanks
    JB
    #476562
    JamButty
    Update. I think I’ve managed to extract an error code. Through fiddling with the buttons I can get into some error code display mode. Here’s what I get each time I then press the prog button.
    1. 13 flashes on the end LED
    2. 13 flashes on the end LED followed by one on the washing phase LED.
    3. 13 flashes on the end LED
    4. 4 flashes on end LED
    5. 5 flashes on end LED
    6. 6 flashes on end LED
    7. 7 flashes on end LED
    8. 8 flashes…
    9. 9 flashes…
    10. 10 flashes…
    11. Back to 13 flashes and the whole loop starts again.
    #476563
    JamButty
    I’ve managed to find this on t’interweb for that fault code.
    Fault
    Problems with the washing motor: no signal from the tachometric generator (washing pump powered, but no signal from the generator)
    Machine status
    The heating element is switched off. If the fault persists after the Time-out, the washing pump operates at maximum speed and the alarm code is stored in memory (the cycle continues)
    Possible causes
    Motor winding interrupted / short-circuited; motor jammed (foreign bodies); wiring to washing motor faulty; motor capacitor faulty; Tachometric generator interrupted / short-circuited; circuit board faulty.
    I’m a modern day Sherlock Holmes
    #476564
    JamButty
    Incidentally, if anyone else needs to read fault codes, here’s how (surprisingly difficult to find this info).
    11 SERVICE MODE
    With this procedure it is possible to access the Service Diagnostics System. To activate the function:
    1. Press and hold down button S2.
    2. PressbuttonS0toswitchtheapplianceon LED L2 flashes.
    LEDs L3 and L4 light up.
    Once this mode is accessed, it is possible to:
    • read and cancel the alarms.
    • control the operation of the various components of the appliance.
    • start the Service diagnostics mode.
    11.1 Reading the alarms and activating the individual components
    After accessing the diagnostics mode:
    1. Wait till LEDs L3 and L4 switch off.
    2. PressbuttonS2.
    the End of cycle LED shows the first alarm memorised with a flashing sequence.
    3. PressbuttonS2othertwotimestodisplaytheothertwomemorisedalarms. the End of cycle LED displays the alarms.
    4. From the fourth activation the test of the single components starts according to the defined sequence
    the LED L3 switches on and remains on for the whole duration of the test of the components. 4th actuation: regeneration solenoid
    5th actuation: drain pump
    6th actuation: water fill solenoid and washing pump (water up to level)
    7th actuation: heating (only if water up to level) 8th actuation: washing pump
    9th actuation: detergent/rinse-aid dispenser
    10th actuation: drying fan
    11th actuation: it starts again from the first alarm
    #476565
    JamButty
    FYI. I ohm tested the tacho (two yellow wires), it showed an open circuit. I bought a BEKO washing machine tacho from some parts place for about £9. Fitted it and it’s done the trick.
    Beer time.
    Mic drop.
    JamButty out.
    #476566
    There there
    To the OP of this thread. Where did you purchase the new tacho from?
    You say you fitted a beko one.
    Im assuming the oe one is intergrated into the motor and would mean replacing the complete unit, is that correct?
    I am having similar issues with my Zanussi zdt21001fa. I originally thought it wasnt heating but it does get warm for part of the cycle but then seems to go on forever.
    I have tried the error code reading and it seems i also have 13 flashes so the tacho could be faulty on mine too.
    I am yet to open it up and check for continuity at the tacho which will be my next step
    #476567
    JamButty
    Bought for a tenner from partscentre.co.uk
    you can just pull out the tacho off the back off the pump/motor, and refit the new one.
    point of interest: there’s a large rather scary looking capacitor on the motor. I wasn’t brave enough to go near it…. suggest you don’t either.
    #476568
    uksaundeda
    JamButty wrote:Bought for a tenner from partscentre.co.uk
    Hi All,
    Just found this post as my ZDT21001FA has started with this fault last week,,
    There are just a few things that I hope people can help with…
    And yes, avoid that capacitor, had a run in with at.. 🙂
    cheers
    #476569
