zanussi zdt21006fa 13 flashes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi zdt21006fa 13 flashes
  • #99866
    mikehha
    can anyone let me have a service manual for this m/c or can you tell me what 13 flashes are (this motor does not have a tacho).
    thanks
    #478226
    let me have the pnc number as i can see 10 machines with the same model. Dated from 2017 to 2021
    13 flashes comes up as tacho on the one i found but want to make sure i send the right info
    mikehha
    thanks dave. pnc no 911539205 00 If it is a tacho then the motor I have 140074403035( which was sent by zanussi ) won`t work because it has no tacho
    #478228
    correct motor for your machine is
    https://shop.zanussi.co.uk/c/circulation-pump-async/p/140002105025
    have you checked the tacho ?
    zanussi dont supply but the beko one fits from what i got told. am fitting one next week so i will know then
    can get you the Beko part no if you need it
    mikehha
    to all you engineers with this fault (which seems to be quite common) I have just fitted a tacho off a hotpoint induction motor also while I had it apart I found that Vestel/yedek washing machine motors have the same tacho. All seems good at the moment !
    #478230
    just fitted the Beko Tacho an hour ago
    part no 372205505
    all well and working, very happy customer
