Zanussi ZDT21006FA Dishwasher no heat 91153920500
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDT21006FA Dishwasher no heat 91153920500
  • #101207
    ray.t
    I had a call to look at this dishwasher this week, the customer said it wasn’t heating. I pulled it out and checked all the usual suspects, the heater and motor tacho but they all checked out fine. I ran the dishwasher to see if I had any power to the heater and it started to heat and worked perfectly. I have since had a call from them saying it hasn’t heated since. Anyone know of any intermittent heating faults on these?
    #483794
    Hollytree_Technical
    I had one where it had an intermittent connection to one of the thermostats on the element (broken spot weld).
    Jem
    #483795
    ray.t
    Thanks, something to look at.
    #483796
    dunston
    We have had a number of these dishwashers with a reported no heat fault and when the tacho is tested it seems OK. And if the element continuity is correct.
    We always replace the tacho. It has worked every time. Beko coil part number 372205506 fits.
    #483797
    ray.t
    Excellent, I will check that out too.
    #483798
    ray.t
    Just thought I would update this. I called back today and the tacho had gone, fitted the Beko tacho and it’s all working fine again.
