Re: Zanussi ZDT41 dishwasher
Ok been back to the machine,cannot possibly remove it! It seems as though the kitchen was built around it …and the water connection is behind a plasterboard wall,running all the way back to the tap!!
Anyway by removing the plinth I was able to access the lower part of the machine and remove the front inspection panel,which also allows the plastic base to drop down enough for a peek inside..
I can’t see any leaks,but more importantly can’t even see a float switch,and as the 3 beeps mentioned in initial post point to the float switch..it’s a bit of a headscratcher at present..
Anyone have any ideas…
