Zanussi ZDT6053 fault code ????????
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDT6053 fault code ????????
  • #62370
    Johnnyboy
    Hi guys I managed a diagnostic but dont have the fault codes for this one, the end cycle light flashed 6 times, the machine wont heat . My feeling is module as the plinth wouldnt come off (siliconed on) Cant find any info. 911939002
    Cheers Johnnyboy
    #349851
    Criscold
    Re: Zanussi ZDT6053 fault code ????????
    Yes its a with a heat problem – let me have your email and I can send you some info
    Colin
    #349852
    Johnnyboy
    johnbasssimpson@googlemail.com cheers hope there is enough info for you
    #349853
    clockworkone
    heat fault is more often than not relay on these. easy to replace as well as no removing of plinth.rs stock no 2509652382 (js1a-5v)paul
