Zanussi ZDT6244 cold water but element seems ok?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi ZDT6244 cold water but element seems ok?
  • #53767
    Hi – I’ve a Zanussi ZDT6244 dishwasher that is not heating the water anymore. I have used a multimeter to test the heater and I’m getting a value of approx 25 ohms. From what I have read here and elsewhere that would indicate that the problem is not there. So I replaced the thermosensor but it still isn’t working. I’ve opened the door up and visually checked the PCB and any connections and I can’t see anything like loose connections or corrosion.
    The heater is like this:(may not be the exact model)
    http://www.espares.co.uk/part/dishwashe … -elem.html
    This is the thermo sensor type (may not be the exact model)
    http://shop.ukwhitegoods.co.uk/Dishwash … ensor.html
    Any advice on where the problem might be would be greatly appreciated.
    Thanks.
    #317161
    TheSpinDoctor
    Re: Zanussi ZDT6244 cold water but element seems ok?
    Hi.
    Sounds from the info that the PCB has failed.
