Zanussi zdt6244 integrated dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi zdt6244 integrated dishwasher
  • #71892
    crockett
    Hi all,I have the above dishwasher and when its turned on it dose nothing at all.Power to machine is ok as is the door switch.The p c b had a damaged relay so I replaced this,I cant see any other obvious signs of damaged on the board.The pump and inlet valve are also ok.Anyone any ideas what might be the problem.Thanks crockett .
    #382717
    Hollytree_Technical
    Re: Zanussi zdt6244 integrated dishwasher
    A bit of a long shot and I know that it sounds daft but does it have any rinse aid in it? I had a Zanussi dishwasher (different model) which I replaced the main pump on that then wouldn’t do anything – turned out that even though the rinse aid light had been on for a couple of months before it must have an internal counter which had hit zero at the same time as I changed the pump so it refused to do anything till I had topped up the rinse aid.
    Jem
    #382718
    Criscold
    Care should be taken relative to the position of connector “A1” – “A2”: if this connector is
    replaced in the incorrect position (back-to-front), the appliance will not function. The board will
    not accept any commands since the power supply will be disconnected
    Its easy on these to reverse the connections A1 – A2 and have done this on a couple. definitely worth checking and the good news is it would not have damage the board if you have.
    Colin
    #382719
    crockett
    Thanks Jem ,only out of salt I’ll top both up and give it a go ,regards Ben .
    #382720
    crockett
    Thanks Colin,I’ve checked that and I have power to the board. The programme light comes on and changes to any required one but there just isn’t a gig out of the machine not even a noise ,thanks again, regards Ben.
    #382721
    crockett
    Thanks Jem and Colin full of salt and rince aid no change and wired properly no change,still as dead as a dódó.Cheers Crockett .
