Zanussi ZDT6252 pnc 911847023 no filling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZDT6252 pnc 911847023 no filling
  • #81519
    allan73
    The above does not fill with water. Is it likely to be a straight valve replacement or could it be something else ?
    Have checked water supply is ok.
    Allan
    #416877
    Re: Zanussi ZDT6252 pnc 911847023 no filling
    It’s a 12 yr old contraption so expect the worst. 😉
    Could be just the aqua valve or a blocked IWMS or pressure switch problems…?..?
    #416878
    allan73
    If the IWMS is blocked can I clean it out Martin ?
    #416879
    allan73 wrote:If the IWMS is blocked can I clean it out Martin ?
    I’ve never tried TBH. Best check it out first eh? See what gives when you go back. 💡
    #416880
    Criscold
    You will not be able to clear the IWMS.
    Try resetting the valve first, sometimes this will work ok but if it locks out again then the IWMS will need replacing along with the valve.
    The IWMS comes complete with the valve
    IWMS Pt No.1524624036
    Colin
    #416881
    allan73
    Thanks Colin, this is a very soft water area so could I get away with valve only ?
    Allan
    #416882
    Criscold
    Possible and sometimes it will be OK,have you tried resetting valve yet ?
    pm your email address if you req the manual for this one.
    Colin
    #416883
    allan73
    Do you mean release the pressure by removing fill hose ? Yes I’ve tried that.
    Allan
    #416884
    Criscold
    Yes that’s correct, Have you got power to the valve and can you hear a faint hum from it, if so I would remove the valve and see if its actually letting water go into the IWMS.
    Colin
    #416885
    allan73
    Yes it was humming Colin. Thanks got advice again.
    Allan
