Zanussi ZDV12002FA Dishwasher Not Heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi ZDV12002FA Dishwasher Not Heating
Viewing 15 posts - 1 through 15 (of 25 total)
  • #95067
    I have the above dishwasher, ZDV12002FA PNC 911 079 006 01.
    About a year ago the machine was leaking and tripping the anti flood alarm, I replaced the sump o ring which fixed it.
    Recently I was getting the flood alarm like before, I watched underneath the machine to see the little overflow tubes filling the base up with water, after some googling I installed the pressure sensor modification kit which solved the overfilling.
    It runs a cycle all the way through fine but now the water doesn’t heat up, is it likely to be a problem with the temperature sensor? It seems strange that after replacing the pressure sensor the temperature sensor would then fail? Or do I need to reset something now a new sensor has been fitted? I’ve tried to find a service manual for this machine but have had no luck.
    Any assistance would be very much appreciated.
    #459254
    first thing to do is check the heater. you have to be certain its ok before you go further
    Thanks for your reply, how do I check the heater?
    #459256
    heater is in the end of the wash motor. you have to disconnect the wires feeding it and use a multi meter to test its resistance
    if its ok I would expect a reading under 100 ohms
    Do I need to remove the whole motor and take out the heater or am I able to test the heater while it is still in situ?
    #459258
    you can test it in situ. you just need access to both terminals
    Ok, I’ll do that this evening and let you know how I get on.
    Thanks for your help so far.
    #459260
    So I ended up taking the motor out as I couldn’t really see which bit was the heater, I’ve attached a link to a photo, what part should I be testing? I’m not sure what terminals I should be putting the multimeter on.
    https://ibb.co/qCH6tNT
    #459261
    the heater is in the front of the motor left of your picture
    can see terminals pic at wrong angle
    Ah ok, I’ve taken another photo, are the two terminals on the left the ones I should be checking?
    https://ibb.co/3rpdnWG
    #459263
    yes top of latest pic
    that’s the heater connections
    So I tested the two terminals at the top (the two inside the little plastic housing) and I’m getting no reading at all, multimeter set to 200 ohms and it’s just showing ‘1’ which is what it shows when it’s not testing anything.
    Does that mean the heater is bust?
    #459265
    yes its blown
    Ok, I’ll order the replacement part. How do I know which one I’ll need? I think the old one says 2040w so will that be the 2000w? First one on the list?
    Out of curiosity what usually cause them to blow?
